| [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) | |
+110ROSSIGRM Daniel A. Haufen wax GtG001 noppie7 Aleph Fügner Brian Callahan Howard Gifford roost t2 190mech ettoiffi lesolexeur Mic Hakkelaar Makr pierre95 GrahamB XpTpSMTT julien #41 rgdavid le vieux docteur romeuh80 SB07 Sabijator ghg02 tz_37 gromono72 Tomi titi rg250 EMOTracing David Matech Solutions zilo bic1983 JoeHännes Riley Will MANETON Jan Thiel bengui LDA Jordan75 tht44 mickie pfpraider cocco83 granjoie Shining jenne smit Michael Burgard nasone32 Camus14 tzpagnol cristogrr 2T4T Alfred Kleis Pickup zelos Institute of TwoStrokes MacPepR 2stroke zeze Emmanuel Laurentz Toop pit Frits Overmars jmdonnat lougassi mike Fonfon #155 pierre Charly phil yanapu bitza32 drt67 superkart eric² Jarno fpayart Team MLR Fabien fab evospeed Ricco#6 Pignool Yonel DAD#21 rs69 Seb4LO ridley 50cc dooky remix31 nsfman philou janpol84 aerophil i-greck Polo les gazs freddy Stephane Inspecteur Harry Thirob jerem-aye mecanik svtce l'occitan Martine Eric Marc 114 participants |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Mer 27 Juin 2012 - 17:10 | |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Mer 27 Juin 2012 - 17:28 | |
| - Howard Gifford a écrit:
- I am curious as to the name 102Tubo? What does this signify?
102 is the serial number, tubo is Italian for pipe . |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Mer 27 Juin 2012 - 17:41 | |
fab evospeed
ROSSIGRM
Nombre de messages : 16 Localisation : PIACENZA ITALY Date d'inscription : 01/02/2011
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Mer 27 Juin 2012 - 20:28 | |
| MANY THANKS FOR THAT MEASURE....I WILL TEST THEM |
GtG001
Nombre de messages : 81 Age : 69 Localisation : Adelaide, Australia Date d'inscription : 02/06/2012
| Sujet: Many Thanks Jeu 28 Juin 2012 - 0:49 | |
| Hi Frits and Jan, I can only speak for myself but it is obvious from the forum that we all hold you two men in high regard both as authorities on the subject of two stroke knowledge but also as generous human beings who enrich the lives of others. Thank you very much for sharing your knowledge with us. Many thanks again.
GtG001
| Sujet: Reed Valve Jeu 28 Juin 2012 - 1:04 | |
| - Jan Thiel a écrit:
- The flow capacity is limited by the reedvalve, not the carburettor.
So it makes no sense using a carburettor bigger than 39. We tried, of course, but it was not better
55 KTM HP is surely at the crankshaft. Hi Jan and Frits, Yamaha has quoted that the reed valve should be about 90% of the flow rate of the Carburettor to keep a good flow rate; is this what you have found or is it a higher figure? I like Frits' idea of the 24/7 reed valve, but it seems to me that only an electronic actuated 24/7 reed valve could response faster enough to provide the power range that we need in motorcycling. Am I wrong in this thinking? Thank you again for your time. |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Jeu 28 Juin 2012 - 11:33 | |
| - GtG001 a écrit:
- ....I like Frits' idea of the 24/7 reed valve, but it seems to me that only an electronic actuated 24/7 reed valve could response faster enough to provide the power range that we need in motorcycling. Am I wrong in this thinking?
In the 24/7-system the reed valve serves to start the engine and to keep it running until it comes into its power band. Once the exhaust resonance sets in, the reed valve is no longer necessary and can be swung out of the way of the inlet flow. That does not require a fast response time at all. Let's take an example of an engine where the power band starts at 10.000 rpm. Then the reed valve should remain in function until at least those 10.000 rpm. But if it is still there at 10.500 rpm, that only means that the engine is still running as a reed valve engine instead of a 24/7-engine. In this transition phase where exhaust resonance is setting in, the power difference will be minor. The 24/7-system will be electronically actuated because that is the simplest way to do it. But it could as well be done centrifugally, like an early exhaust power valve. In fact the 24/7-system should be opened at about the same rpm as such an exhaust valve. |
Howard Gifford
Nombre de messages : 140 Age : 68 Localisation : Ottawa Canada Date d'inscription : 01/05/2012
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Jeu 28 Juin 2012 - 19:49 | |
| Hi Frits. I am a bit skeptical about your 24-7 idea. Perhaps you could enlighten me as to how it will help power output. It is my experience that a rotary valve engine loses power with closing after 105 degrees. A 24-7 design has no closing. I have tested up to 135 degrees closing. Using my variable timing to start the motor I have found a large drop in power starting at 110 degrees increasing to where the motor loses 10 hp at 135 degrees closing and is very sluggish to respond at lower than optimum rpm. I can not start the motor with anything over 135 closing (110 closing with the variable timing at full advance) Does your design rely solely on intake resonance to operate? |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Jeu 28 Juin 2012 - 21:34 | |
| It does rely on the reed valve for starting, so that is one problem out of the way. It does not rely on intake resonance at all, as there is no intake resonance as such. A racing two-stroke engine is a compound resonance system because all ports are open simultaneously at one time or another. Flow through the engine is mainly governed by the exhaust system but a lot of other factors come into play; you cannot separate the inlet part. Your experience with late inlet closing is valid for your engine, no doubt, but what crankcase volume did you use? That is one of the important factors where the 24/7-system probably differs a lot from conventional engines. |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Jeu 28 Juin 2012 - 21:46 | |
| I regret to say that I have just blocked my private message-option. Dealing with private messages was taking up ever more of my time and finally I simply could not answer all questions any more. To those of you who sent me private messages: please do not feel offended. I can very well understand your desire to ask all kinds of questions; I would probably do the same if I were in your position. But I hope you can also understand my position. I will gladly continue to answer any questions that are asked in public, in the forum, so that all forum members can take notice. Sincerely, Frits Overmars |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Jeu 28 Juin 2012 - 22:04 | |
| Thank you, Frits! |
MINGRET01
Nombre de messages : 27 Localisation : lyon Date d'inscription : 19/11/2011
| Sujet: RSA CYLINDER Ven 29 Juin 2012 - 13:43 | |
| [Vous devez être inscrit et connecté pour voir cette image]Hello Mr OVERMARS I watch your topics with interest. On a other topic you had put drawing of RSA cylinder.I have many question: When you watch drawing "SEZIONE AA" the A-port is at left and B-port at right that's good? If A-port is at left, when I watch drawing angular to exit port is more important than B-port? Principal transferts are more inclination than auxiliary transferts is that. I see also that B-port (90-42)is higther than A-port (90-43.1) it's right? For finish witch values did you have at timing transfert port and exhaust port with valve open in this cylinder? Thanks for answer Mr MINGRET |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Ven 29 Juin 2012 - 14:06 | |
| - MINGRET01 a écrit:
- When you watch drawing "SEZIONE AA" the A-port is at left and B-port at right that's good?
Yes - Citation :
- If A-port is at left, when I watch drawing angular to exit port is more important than B-port?
No. It's not more important, but it is larger, if that is what you mean.(this may be a language problem). - Citation :
- I see also that B-port (90-42)is higther than A-port (90-43.1) it's right?
Yes - Citation :
- For finish witch values did you have at timing transfert port and exhaust port with valve open in this cylinder?
Exhaust 202°, A-transfers 130°, B- and C-transfers 132°. |
Mic
Nombre de messages : 62 Localisation : Denmark Date d'inscription : 12/02/2012
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Ven 29 Juin 2012 - 18:30 | |
Hello Mr OVERMARS
Thanks for answer
Mr MINGRET Do you've a link to to a high resolution picutre? It's almost impossible to read most of the measurements |
MINGRET01
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Ven 29 Juin 2012 - 18:45 | |
| Thank Mr OVERMARS for your answers. By angular ,I means the inclination where transferts exit to cylinder.see drawing following: [Vous devez être inscrit et connecté pour voir cette image]On drawing "SEZIONE AA" angular for A-port is 28.16° and for B-port is 6.82°.Is exact or the both transferts are the same angular? Mr MINGRET |
pierre95
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Ven 29 Juin 2012 - 18:53 | |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Ven 29 Juin 2012 - 20:02 | |
Daniel A.
Nombre de messages : 55 Localisation : Germany Date d'inscription : 20/02/2012
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Lun 2 Juil 2012 - 9:03 | |
| I see, that the "back pushing" cone of the Aprilia exhaust has got 3 parts, first one with the lowest angle and third one with the highest. Is this to make the power band more "symmetrically" (more torque to lower revs and less torque to higher revs) or does this also bring more maximum power than a cone with one and the same angle?
Regards |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Lun 2 Juil 2012 - 9:32 | |
- By angular ,I means the inclination where transferts exit to cylinder.
On drawing "SEZIONE AA" angular for A-port is 28.16° and for B-port is 6.82°. You just answered your own question . - Daniel A. a écrit:
- I see, that the "back pushing" cone of the Aprilia exhaust has got 3 parts, first one with the lowest angle and third one with the highest. Is this to make the power band more "symmetrically" (more torque to lower revs and less torque to higher revs) or does this also bring more maximum power than a cone with one and the same angle?
The three-part reflector is a relic of evolution, like an appendix. I think a single cone can be just as effective. |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Lun 2 Juil 2012 - 14:08 | |
Do you've a link to to a high resolution picture? It's almost impossible to read most of the measurements Here, Mic: [Vous devez être inscrit et connecté pour voir ce lien] |
Mic
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Lun 2 Juil 2012 - 18:16 | |
| Thank you Frits. Old APC cylinder but the ports still looks quite good |
Brian Callahan
Nombre de messages : 19 Localisation : San Diego, USA Date d'inscription : 13/05/2012
GtG001
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Mar 3 Juil 2012 - 4:48 | |
The three-part reflector is a relic of evolution, like an appendix. I think a single cone can be just as effective.[/quote] Hi Frits, thank you for sharing the drawings of the cylinder; it is very interesting to see these – there is a lot of design work there – nothing by chance as it would seem? Previously, you had said that if a convergent cone angle is too steep, it creates a shock wave which is inefficient for pushing the charge back into the cylinder – at what angle range does this happen for the convergent cone? Many thanks for being part of this interesting forum – could you give me the link of any other themes on this forum where you are contributing - I am very much enjoying reading what you, Jan and the others say on this forum – thank you Marc for hosting the web site. |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) Mar 3 Juil 2012 - 7:03 | |
| - GtG001 a écrit:
- Previously, you had said that if a convergent cone angle is too steep, it creates a shock wave which is inefficient for pushing the charge back into the cylinder – at what angle range does this happen for the convergent cone?
One cannot quote a cone angle for this phenomenon, Allan. The stronger the initial pulse and the greater the distance from the reflector back to the cylinder, the greater the risk of the return pulse developing into a shock wave before it arrives at the cylinder, and the shallower the reflector needs to be. - Citation :
- could you give me the link of any other themes on this forum where you are contributing
Click on 'Frits Overmars' at the left of this text. On the page that appears, click on 'Sujets' which will give you a survey with about '190 résultats trouvés pour Frits Overmars', or click on 'Messages' which will give you a survey with about '292 résultats trouvés pour Frits Overmars'. That will keep you off the street for a while... You can of course do the same with Jan Thiel's name or with any other contributor to this forum. |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 1) (Locked) | |
