Qui est en ligne ? | Il y a en tout 115 utilisateurs en ligne :: 5 Enregistrés, 0 Invisible et 110 Invités :: 2 Moteurs de recherche 121212, Adco, BauGG, cassandre, DidierFLe record du nombre d'utilisateurs en ligne est de 588 le Jeu 26 Sep 2024 - 6:33 |
| [2 strokes] V2 90 degree, common crankcase,one carb | |
+8GrahamB cristogrr Frits Overmars Pline le nouveau superkart Ed Marc Niels Abildgaard 12 participants | |
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb Lun 10 Fév 2014 - 11:36 | |
| - GrahamB a écrit:
- I think the special wrist-pins Aprilia used with the ends welded shut were made by Mahle, but I would guess costs would be high unless you ordered a few hundred.
They were made by Pankl of Austria and if I could afford a few hundred of their pins I would take a year-long vacation instead. |
| | | Pline le nouveau
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb Lun 10 Fév 2014 - 22:41 | |
| I am sorry for you and your wife ..... I hope your project help you to be strong , good luck , i don t speak English very well , so i can t help you because i don t understand all you make , sorry..... |
| | | Fügner
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb Mar 11 Fév 2014 - 10:23 | |
| | | Niels Abildgaard
Nombre de messages : 37 Localisation : Denmark Date d'inscription : 26/02/2013
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb Mar 11 Fév 2014 - 18:41 | |
| - Pline le nouveau a écrit:
- I am sorry for you and your wife .....
I hope your project help you to be strong , good luck , i don t speak English very well , so i can t help you because i don t understand all you make , sorry..... Thank You Pline and I appreciate You writing in english much better than my french. [Vous devez être inscrit et connecté pour voir ce lien]First picture is a V2 90 degree for being ligther, less vibrating and using less fuel than Rotax 912 for aircrafts with 60 to 80 horsepower Next three pictures are a radical test engine for Junkers research,both aircraft and Junkerator(The twin AC generator thing) [Vous devez être inscrit et connecté pour voir ce lien]A much simpler solution is to take the two scrap MZ150 crankcases/cranks I have here,but straigthforward solutions was never my way [Vous devez être inscrit et connecté pour voir cette image]I know it has nothing to do with motorbikes but reading all from the two gentlemen from Aprilia has been a great pleasure and I hope some enjoy my pictures
| | | Niels Abildgaard
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb Mar 11 Fév 2014 - 19:07 | |
Emmanuel Merci beaucoup Niels |
| | | Niels Abildgaard
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb Mar 11 Fév 2014 - 19:18 | |
| - Fügner a écrit:
- cristogrr a écrit:
- Hello,
the main problem is the accumulation of heat on the pistons (internal parts are difficult to cool) Un "moteur" parfaitement "refroidi" ne produit plus de travail et s'appelle une "chaudière"
Niels nous parle du rendement, le vrai Hello Fugner Racing engines shall make so much horsepower as possible for a limit of cubic centimeters . Fuel consumption and vibrations are not so important. Aircraft engines are different but still better if two stroke and the two stroke pollution/cleanness problem is not so great for aeroplanes but noise is. |
| | | Fügner
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb Mar 11 Fév 2014 - 23:52 | |
| Racing is only to play ! Sulzer two stroke or Junkers opposite engine is to work. |
| | | magma
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb Mar 20 Oct 2015 - 21:47 | |
| Habituellement sur un OP engine (equicourant) on décale les deux pistons pour diminuer le croisement admission-échappement. (de 15° environ)
Soit par la liaison des deux bas moteur, soit avec une bielle principale et une secondaire ou à fourche sur un moteur en U; Qui n'est rien d'autre qu'un OP replié... (puch, DKW...etc);
Pour éviter d'utiliser des carters pompe de 2 temps il est souvent couplé à un compresseur. |
| Sujet: Re: [2 strokes] V2 90 degree, common crankcase,one carb | |
