Nombre de messages : 12435 Age : 47 Localisation : Campagne angevine Date d'inscription : 30/10/2008
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Ven 12 Juin 2015, 14:31
A la chasse au Micowoy
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Ven 12 Juin 2015, 16:05
julien #41 a écrit:
Je parlais juste de calculer la section de passage dans le gicleur réglable correspondant à un gicleur donné qui fonctionne sur ce moteur pour avoir une base de réglage pour le premier démarrage. Le calcul est pas très compliqué.
Julien, can you show me your simple calculation of the available flow area in this real-life example, where the needle is not completely centered in the jet bore, which is usually the case, and with respect to the boundary layers of stagnating fluid inside the jet bore and around the needle? [Vous devez être inscrit et connecté pour voir cette image]
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Ven 12 Juin 2015, 17:27
Frits I just talk about the adjustable jet of Micowoy where the needle (for the jet size adjustment) is centered in the hole for the setting of the gas flow, that is simple to calculate or design with 3D sotware.
I don't speak about the throttle valve needle wich is I agree very difficult to calculate according to the position of the needle and his radial free play..
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Ven 12 Juin 2015, 18:40
julien #41 a écrit:
Frits I just talk about the adjustable jet of Micowoy where the needle is centered in the hole
So did I, Julien. You can only be sure that a needle is centered in a hole if there is zero diameter difference (which would be rather bad for fuel flow), or if there is a very long, tight guidance. Often, when certain settings could not be repeated, the cause turned out to be a very slight tilting of the needle. Without the boundary layers this tilting would not make any difference, but alas, reality is not so forgiving.
About the throttle valve needle: you may have noticed that in some carburetters the needle is spring-loaded laterally, so it is always pushed against the same side in the needle holder, preventing the above-mentioned problem. Another trick is a small O-ring tightly around the needle, between the needle clip and the slide body. This prevents vibrations of the needle, that would otherwise noticeably influence the fuel flow. These little details were the result of much head-scratching .
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Ven 12 Juin 2015, 20:47
Il est toujours intéressant de prendre connaissance de plusieurs aspects du problème...
Nombre de messages : 151 Age : 60 Localisation : Belgique Date d'inscription : 23/09/2012
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Sam 13 Juin 2015, 00:35
oui ,l'aiguille à du jeux dans le boiseau ,et celui ci dans le corps ...,après chaque démontage de cuve je dois la recentrer avec 1 axe centreur dans le gp mais il y a toujours 1 jeux mini pour le fonctionnement,c'est inévitable
micowoy
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Dim 14 Juin 2015, 21:12
Frits, I really don't want to contradict or reinvent your works, at the started of the discussion I just said that it was possible to approximate (by calculate, modelisation or test like Micowoy as done) the setting of the adjustable jet to rich a known jet size to start the engine and begin the real setting..
I always said that this first setting is "approximate", I know that an accurate setting depend of many parameters and the case of the throttle valve needle is another really interesting problem.
And finally many thanks Frits to share your knowledges here.
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Mar 16 Juin 2015, 21:14
Je suis Fan micowoy, j'espère la voir de près le mois prochain
Je ne manquerai pas de venir voir ça de près
micowoy
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Mar 16 Juin 2015, 21:51
Tu monte à Chimay ,
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Mar 16 Juin 2015, 22:32
On va même rouler ensemble
micowoy
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Mer 17 Juin 2015, 14:24
Bonne nouvelle ,vous etes déjà inscrits ? [Vous devez être inscrit et connecté pour voir ce lien]
Sujet: Re: [2 stroke] Honda RS 125 rotary valve Mer 17 Juin 2015, 14:51
Oui Etienne en ipc125 et moi en EVO
etienne24II
Nombre de messages : 37 Age : 39 Localisation : Douarnenez (29) Date d'inscription : 22/10/2011
