| [Technique chassis] Hossack ZX10R | |
+20sdvs fd-racing Team TZ lzf62 bartau Vivien57 Motors31 crigar Rose Noire Adco EDOUARD Jean Athily Frits Overmars fpayart MANETON bentou Pomme Ed Dan42 Laurence Smith 24 participants |
| Sujet: Re: [Technique chassis] Hossack ZX10R Jeu 2 Nov 2017 - 11:34 | |
| - bentou a écrit:
- Very nice.
belle et intelligente réalisation, très propre effectivement proche de la technique de modification du cadre d'origine que nous avons appliqué avec la Metiss. Comment comptez vous traiter la direction? |
| Sujet: Re: [Technique chassis] Hossack ZX10R Jeu 2 Nov 2017 - 11:35 | |
| - bentou a écrit:
- Very nice.
| Sujet: Re: [Technique chassis] Hossack ZX10R Jeu 2 Nov 2017 - 11:55 | |
| - Laurence Smith a écrit:
- I was at the 2011 Le Mans 24H and I spent quite some time looking at the Metiss as you were preparing it...inspirational
Laurie, what made you decide to go the Hossack route and not the JBB route? Lower arm attachment issues? Steering movement limitations? |
Laurence Smith
Nombre de messages : 54 Localisation : Canberra Australia Date d'inscription : 26/11/2015
| Sujet: Re: [Technique chassis] Hossack ZX10R Jeu 2 Nov 2017 - 20:43 | |
| - BRUNEAU a écrit:
- bentou a écrit:
- Very nice.
belle et intelligente réalisation, très propre effectivement proche de la technique de modification du cadre d'origine que nous avons appliqué avec la Metiss. Comment comptez vous traiter la direction? Cheers Bruneau :-) Not sure about your Question...it doesn't translate very well I think. Keeping the design simple and clean has been a priority...as is simplifying manufacture through the use of Waterjet cutting parts for example..... |
Laurence Smith
| Sujet: Re: [Technique chassis] Hossack ZX10R Jeu 2 Nov 2017 - 20:58 | |
Laurie, what made you decide to go the Hossack route and not the JBB route? Lower arm attachment issues? Steering movement limitations? I have long been an admirer of people like Hossack and Fior so have always wanted to emulate their work......I remember in the late Eighties drawing complete Hossack/Fior bike layouts on my bedroom wall at 1:1 scale and figuring out their instantaneous centres etc ....now that is coming to fruition..... Designing/building a Hossack/Fior for me tends to be easier in that I can use and modify an existing frame like I have done and also things like front wheels and brakes remain the same where as a JBB is more challenging in these respects ....I am a little lazy in some ways :-) |
Laurence Smith
| Sujet: Re: [Technique chassis] Hossack ZX10R Ven 24 Nov 2017 - 1:13 | |
| Handlebars done and steering damper fitted.... [Vous devez être inscrit et connecté pour voir cette image] |
Athily
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 9:33 | |
| Why you don't put the screw like this, in the same postion of the top ? [Vous devez être inscrit et connecté pour voir cette image] |
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 11:08 | |
| Indeed, the position is not very orthodox, but Laurence surely has a good reason, and the rocker deflection angle is still probably less than the allowable value of the ball joint. |
Nombre de messages : 8926 Localisation : Margerie-Chantagret 42 Date d'inscription : 06/04/2014
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 11:31 | |
| The reason is probably less material on the lower rocker, to save weight! Dan |
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 12:47 | |
| - fpayart a écrit:
- Indeed, the position is not very orthodox, but Laurence surely has a good reason, and the rocker deflection angle is still probably less than the allowable value of the ball joint.
C'est le sens de la rotule a 90° qui te perturbe ? Je me suis fais la même réflexion ? Suivent l'angle de fonctionnement ? Ce n'est pas rédhibitoire |
Nombre de messages : 20365 Age : 78 Localisation : ARGELIERS dans L'Aude Date d'inscription : 14/08/2011
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 12:52 | |
| C' est peut être pour une facilité pour le démontage de l' amortisseur quand tous les accastillages sont en place . |
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 13:16 | |
| Totally agree with you all, Laurence alone can give us the true reason. Or not. |
Athily
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 21:58 | |
C'est justement pour en connaitre la raison, a voir ce qu'il construit, ses connaissance doivent de loin dépasser les mienne. C'est juste que dans ma tête, ce choix n'est pas logique |
Nombre de messages : 6486 Localisation : Limoges Date d'inscription : 19/02/2016
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 22:17 | |
| Pendant toute l'époque des grands prix dans les années 60,Honda a monté ses amortisseurs de direction de cette façon,ça me semble anti mécanique mais je pense qu'ils avaient une bonne raison....Que je n'ai pas trouvée ! [Vous devez être inscrit et connecté pour voir cette image] |
Laurence Smith
| Sujet: Re: [Technique chassis] Hossack ZX10R Dim 26 Nov 2017 - 23:28 | |
| The reason why I did this is so that I can move the lower shock pivot point 5 mm back or forwards
This slightly changes the leverage ratio and so changes wheel rate ( spring rate measured at the wheel )
Because this suspension uses a lower leverage ratio 1.4:1 it uses spring rates in the lower rate range
40N/mm......this means that when I change spring rates there is a higher percentage change in spring
rate ( and so wheel rate ) so its difficult to fine tune the wheel rate.
For example when changing springs in the higher spring rate range as typically found in most rear
suspension designs with a higher leverage ratio 105N/mm too a 110N/mm this is a 4.7% change in
spring rate and wheel rate.
When in my suspension changing from a 40N/mm spring too a 45N/mm spring this is a 12.5% change
in spring rate and so wheel rate which is a large change.....the adjustable lower shock pivot allows
me to better control the wheel rate when I change spring rates.
This change in the lower mount configuration does stress the spherical bearing in a less than ideal way....but the lower leverage ratio its being used with means lower peak loads than what the bearing was designed for. |
| Sujet: Re: [Technique chassis] Hossack ZX10R Lun 27 Nov 2017 - 0:10 | |
| It's a good reason. |
| Sujet: Re: [Technique chassis] Hossack ZX10R Lun 27 Nov 2017 - 8:52 | |
| OK, par cette disposition: possibilité d'avancer ou reculer le centre de rotation de la rotule inférieure d'amortisseur de +- 5mm, dans l'optique de minimiser les variations de rapport de dureté ressort dues a ce montage, tout en restant dans les capacités de la rotule. Bien vu, simple et efficace. Dan |
| Sujet: Re: [Technique chassis] Hossack ZX10R Lun 27 Nov 2017 - 11:46 | |
| - fpayart a écrit:
- It's a good reason.
It's the same reason that lead to radial brake calipers: you can adapt their position to different brake disc diameters with just a couple of distance pieces. [Vous devez être inscrit et connecté pour voir cette image] |
Athily
| Sujet: Re: [Technique chassis] Hossack ZX10R Lun 27 Nov 2017 - 19:19 | |
| Ca c'est de l'explication, merci |
Laurence Smith
| Sujet: Re: [Technique chassis] Hossack ZX10R Lun 27 Nov 2017 - 21:52 | |
| Thanks everybody |
| Sujet: Re: [Technique chassis] Hossack ZX10R Mar 28 Nov 2017 - 9:15 | |
| Simple and smart assembly. |
Nombre de messages : 2251 Age : 67 Localisation : Ruoms 07 Ardèche Date d'inscription : 14/02/2013
| Sujet: Re: [Technique chassis] Hossack ZX10R Mar 28 Nov 2017 - 9:39 | |
| Je suis complètement largué, mais je me rends compte qu'aux antipodes aussi il y a du jus de cervelle qui fermente ! |
Motors31
| Sujet: Re: [Technique chassis] Hossack ZX10R Mar 28 Nov 2017 - 12:18 | |
| Merci a Dan 42 pour la traduction , moi c'est la dissymétrie avec un seul amortisseur qui chiffonne mes neurones dont la qualité et la quantité n'a rien a voir avec celle de Laurence car sur un effort violent ça ne risque t'il pas d'engendre une torsion laterale du bras ? Sur la photo de Frits l'amortisseur est au milieu de train et j'aime bien même si c'est juste un confort visuel . Dans ce projet pas de grandes promesses c'est probablement ce qui le rend si sympathique ...... Thanks Laurence !
Vivien57
| Sujet: Re: [Technique chassis] Hossack ZX10R Mar 28 Nov 2017 - 12:58 | |
| J'aime bien l'assymétrie(justifié), ça donne un sens aux pièces que l'on dessine. Hors-sujet, [Vous devez être inscrit et connecté pour voir ce lien]Par exemple, quand tu prends un visage créer en image de synthèse ton cerveau le juge imparfait, robotique, car pas habitué aux visages parfaitement symétrique. |
| Sujet: Re: [Technique chassis] Hossack ZX10R Mar 28 Nov 2017 - 13:31 | |
| - Motors31 a écrit:
- Sur la photo de Frits l'amortisseur est au milieu de train et j'aime bien même si c'est juste un confort visuel.
I like symmetry too, and on the picture I posted, from Lauries previous project, the shock absorber was really in the center. But for his new creation Laurie wanted to maintain the central air intake of the Kawa ZX10R, so the shock absorber had to move sideways. [Vous devez être inscrit et connecté pour voir cette image] |
| Sujet: Re: [Technique chassis] Hossack ZX10R | |
