| [Petites annonces] Cherche pièces Moteur RS500 Honda | |
+10GrahamB Jarno philippe7 Kentai bubu Alain Chevallier Pickup Marc clauderochefort Gull 14 participants |
FX916
Nombre de messages : 109 Age : 62 Localisation : La Garenne Colombes Date d'inscription : 06/07/2011
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Lun 12 Mai 2014 - 21:19 | |
| Troisième essai, mais le post date de 2010 !
http://www.tz250.com/forums/archive/index.php/t-6962.html
For sale Honda RS 500 3 cylinders from 1988 spare parts. Most of the are brand new and some used in different conditions. Complete list as follows: REF ITEM QTY STATUS 13101-ND7-810 PISTON 3 NEW 13101-ND7-810 PISTON 21 USED 94601-16000 PISTON CLIP 2 NEW 12101-NF7-000 CYLINDER 1 NEW 12101-NF7-000 CYLINDER 1 USED 12201-NF7-000 CYLINDER HEAD 1 USED 12202-NF7-000 CYLINDER HEAD 1 USED 13000-NF7-000 CRANKSHAFT 1 USED FOR REPAIR 22401-NC8-000 SPRING CLUTCH 6 USED 22201-NC8-000 CLUTCH FRICTION DISC A 8 USED 22311-NF7-003 PLATE A CLUTCH 8 USED 30300-NC8-000 GENERATOR ASSY PULSE 1 NEW 18212-NF7-000 GASKET EXHAUST JOINT 3 NEW 14132-430-000 GASKET A REED VALVE 10 NEW 14133-430-000 GASKET B REED VALVE 9 NEW 12192-NC8-000 GASKET CYLINDER 24 NEW(SEVERAL SIZES) 19223-NC8-000 GASKET WATER PUMP COVER 2 NEW 19222-NC8-000 GASKET WATER PUMP CASE 3 NEW 11351-ND7-810 GASKET ATTACK COVER 4 NEW 11394-ND7-810 GASKET L COVER 4 NEW 11395-NC8-000 GASKET R COVER 4 NEW 31930-ND5-003 SPARK PLUG 3 NEW 12211-NC8-000 O RING CYLINDER HEAD O.S. 4 NEW 91203-NF7-003 OIL SEAL 34x68x6 4 NEW 91204-NF7-000 OIL SEAL 31,5x62x6 1 NEW 91007NC8-000 BEARING NEEDLE 30x35x24 1 NEW 91020-NC8-000 BEARING NEEDLE 22x33x15 SPL 1 NEW 91001-NF7-300 BEARING COMP 6305 1 USED 91005-NF7-300 BEARING COMP ROLLER B 1 USED 91054-NC8-000 BEARING TAPPER 25x52x16,25 1 NEW 91021-890-000 BEARING NEEDLE 15 1 NEW 91304-NC8-000 O RING 18x1,58 1 NEW 91207-NF7-003 OIL SEAL 32x43x6 1 NEW 91206-GJ5-004 OIL SEAL 10x20x5 1 NEW 91206-ND7-810 OIL SEAL 10x25x5 1 NEW 24435-NC8-000 SPRING DRUM STOPPER 1 NEW 90472-NC8-000 STOPPER PRIMARY BEARING 1 NEW 28815-NF7-000 SPRING CLUTCH LEVER 1 NEW 93600-06012 SCREEW FLAT 6 x 12 3 NEW 90471-NC8-000 STOPPER BEARING'1 NEW 19230-NC8-000 IMPELLER WATER PUMP 1 NEW 90201-415-000 NUT CAP 6MM 1 NEW 16112-NC8-004 WASHER HOLDING BOLT 1 NEW 91301-NC8-005 O RING 25x28x5 1 NEW 96211-07000 BEARING BALL 63/22 2 NEW 90604-MG8-000 CIR CLIP 30 3 NEW 90602-NC8-000 CIR CLIP 28 1 NEW 51404-NC8-810 FRONT FORK SPRING 0,7 2 NEW 51402-NC8-810 FRONT FORK SPRING 0,6 2 NEW 52402-NC8-000 SPRING REAR CUSHION 1 NEW 52401-NC8-000 SPRING REAR CUSHION 1 NEW 91008-NF7-000 BEARING BALL 6305 1 NEW 90602-463-000 CIR CLIP 28 8 NEW 94510-10000 CIR CLIP EXHAUST 10 1 NEW 18266-ND7-810 ROD ATAC 2 1 NEW 18265-ND7-810 ROD ATAC 1 1 NEW 19535-NF7-000 HOSE WATER MIDDLE 1 NEW 90123-NF7-000 BOLT ENGINE HUNGER SOCKET 12x318 1 NEW 90305-393-000 NUT AXLE 18 MM 1 NEW 90121-NF7-000 BOLT SOCKET ENGINE HANGER 10x287 1 USED 90122-NC8-000 BOLT ENGINE HANGER SOCKET 10x281 1 USED 22870-NC8-000 CABLE COMP CLUTCH 1 NEW 17910-ND7-000 CABLE A COMP THROTTLE 1 USED 17920-ND7-000 CABLE B COMP THROTTLE 1 USED 51360-NC8-000 LEVER, HANDLE BRAKE 1 NEW 45107-NC8-000 PAD COMP FRONT A 4 NEW 45108-NC8-000 PAD COMP FRONT B 4 NEW 45107-NC8-000 PAD COMP FRONT A 2 USED 45108-NC8-000 PAD COMP FRONT B 2 USED 50640-NF7-000 HOLDER L STEP 1 USED 50630-NF7-000 HOLDER R STEP 1 USED 53141-NC8-000 PIPE THROTTLE GRIP 1 USED FOR REPAIR 51412-NC8-000 RETAINER DUST SEAL 2 NEW 14111-NF7-003 REED VALVE ONLY 10 USED 23802-NC8-000 SPROCKET DRIVE 15 T 1 USED 23804-NC8-810 SPROCKET DRIVE 17 T 1 USED 90022-NF7-000 BOLT STUD CYLINDER 3 USED SPECIAL TOOL 2 USED WORKSHOP MANUAL 1 USED
Asking 3.500 euros for all with shipments cost included worldwide. A very good opportunity for someone owning one of this exclusive 500 GP bikes. |
Gull
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Lun 12 Mai 2014 - 21:34 | |
FX916
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Lun 12 Mai 2014 - 21:41 | |
| Encore un peu de google [Vous devez être inscrit et connecté pour voir cette image]http://eshop.original-teile.de/index.php?cl=search&searchparam=13101ND7810&lang=1 Brand HONDA: PISTON COMP A Partno.: 13101ND7810 Available in approx. 7-10 working days 123,55 € * |
philippe7
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Lun 12 Mai 2014 - 23:25 | |
| - Gull a écrit:
- Du tac au tac, je vous réponds que vous êtes de vilains taquins.
j'ai édité le titre. Je lance une refabrication de pistons pour 500 NR, sur une base de cendrier. Sachant que si j'en fais des pelles carrées, le prix de revient est absolument délirant, qui qu'en veux? C'est pas très vendeur, je recommence: Un chouette mien ami qui est du métier me propose la refabrication de pistons après relevage de cotes sur un piston à peine rodé ( 150 km tout au plus ) en en faisant faire par poignée de 24, on arrive à 80€HT le bout. Ce n'est pas donné, mais vu la disponibilité sur le marché, le choix est assez limité.
si vous êtes intéressé, faites vous connaitre, si vous ne l'êtes pas, colportez la nouvelle. Je vais encore faire du mauvais esprit, mais bon ...... Gull, j'espère que tu vas trouver ton bonheur dans toutes les propositions ci-dessus , parceque si tu es obligé, comme tu l'envisages, de lancer une refabrication de pistons de 500 NR ( qui ont la particularité d'être de forme ovale ) , tu risques d'avoir du mal à les faire rentrer dans les cylindres de ta bécane... |
Gull
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 8:56 | |
| - philippe7 a écrit:
Je vais encore faire du mauvais esprit, mais bon ...... Gull, j'espère que tu vas trouver ton bonheur dans toutes les propositions ci-dessus , parceque si tu es obligé, comme tu l'envisages, de lancer une refabrication de pistons de 500 NR ( qui ont la particularité d'être de forme ovale ) , tu risques d'avoir du mal à les faire rentrer dans les cylindres de ta bécane... On a bien noté qu'ils étaient ovales ( depuis un certain temps déjà) et la refabrication se fait sur la base de pistons existants ( TZ 750,) puis mis aux cotes ET ovalisés. le poids final augmente d'une dizaine de grammes. Le but est de rouler, pas d'aller chercher les usines, on n'y arrivait pas il y a 25 ans, on voit bien que l'écart ne s'est pas réduit aujourd'hui. |
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 14:27 | |
| Gull, je crois que Philippe parle des pistons de la 750 NR: [Vous devez être inscrit et connecté pour voir cette image]Qui devraient avoir du mal à renter dans le trois pattes à trous... même ovalisés... |
Gull
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 15:01 | |
| Les pistons de l'Ahoud sont vraiment ovales. Quand Papy Alain aura fini sa sieste et mouillé sa madeleine dans le thé, il ne manquera pas de nous expliquer pourquoi, du genre " c'est pour que quand c'est tout bien chaud ça devienne cylindrique" |
Gull
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 15:02 | |
| Et oui, je me suis encore planté entre NS NR et RS. Ce que vous pouvez êtres agaçants à la fin. |
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 15:25 | |
| Eh oui, Never Start, Never Ready... pas compliqué à se souvenir RS, tu propose quoi ? Ratagaz Salace ? |
Gull
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 15:55 | |
| Recherche Sponsors? |
general-nemesis
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 16:50 | |
| Salut Rapidement Serrée Pour un 2 temps cela me semble de bon aloi |
Gull
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 17:02 | |
general-nemesis
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 17:24 | |
| Salut Blague a part j espère que tu vas trouver ton bonheur afin de redonner vie a ta merveille |
Gull
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 18:34 | |
| Merci Mon Général. Elle va tourner. On passe à peine le doigt entre piston et cylindre. |
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda Mar 13 Mai 2014 - 23:16 | |
| Tous les pistons sont ovales et coniques, ceci pour compenser les différences de dilatations dues aux différences de températures et aux différences locales d'épaisseurs de matière. Ovale et conique, c'est un peu raccourci, disons que la forme est proche d'un ovale conique. |
| Sujet: Re: [Petites annonces] Cherche pièces Moteur RS500 Honda | |
