Qui est en ligne ? | Il y a en tout 53 utilisateurs en ligne :: 6 Enregistrés, 0 Invisible et 47 Invités :: 2 Moteurs de recherche Alain Gwada, JH42, lebougladit, marco91, neoraptor, PaulusLe record du nombre d'utilisateurs en ligne est de 539 le Mar 19 Mar 2024 - 12:10 |
| | [GP250] KTM 250 | |
+15MANETON Toop Frits Overmars pipoff2 superkart ridley Eric Offenstadt Stephane Seb4LO remix31 Pignool janpol84 i-greck nsfman Marc 19 participants | |
| Sujet: Re: [GP250] KTM 250 Mar 28 Avr 2020 - 10:19 | |
| - Toop a écrit:
- Thanks Frits, any crankshaft of this sheet ?
No pictures of the crankshaft, but nevertheless a little more information: in contrast to the usual 180° firing order of a parallel twin, the KTM GP250 has a 90° / 270° firing order, making the balance shaft indispensable. - MANETON a écrit:
- Je suis surpris de l'utilisation de thermocouple type J ou K. J'ai toujours eu l'impression, peut-être erronée, qu'ils n'étaient parmi les plus réactifs. A moins que ça ne provienne des caractéristiques de la sonde ou du traitement du signal.
J- and K-thermocouples are quite fast, but the response time of most industrial thermocouples is severely impaired by their shielding. The actual thermocouple, consisting of two dissimilar electrical conductors forming an electrical junction, is embedded in ceramic and additionally packed in a stainless steel sleeve. Without all this shielding, a thermocouple can respond a hundred times faster to temperature changes. That is why I make open-junction K-thermocouples myself, using a bobbin of chromel wire and a bobbin of alumel wire. The wires can be joined with silver brazing or with spotwelding, using a capacitor discharge in the same way that we make ignition glow plugs. Without the shielding of industrial thermocouples, homemade thermocouples do not have eternal life, but that is more than made up for by their fast response time. And it is not that difficult and not that expensive to make them yourself.
| | | AG72
Nombre de messages : 36 Age : 24 Localisation : Le Mans/Orléans Date d'inscription : 21/04/2020
| Sujet: Re: [GP250] KTM 250 Mar 28 Avr 2020 - 10:39 | |
Hello, Thanks for the infos! I understand that, but with a 180° crank their still is a secondary order imbalance no? I dont know the length of the rod and the stroke, but since it must rev hight, they may not be negligible?
| | | pipoff2
Nombre de messages : 148 Localisation : nantes Date d'inscription : 25/07/2010
| | | | fpayart
| Sujet: Re: [GP250] KTM 250 Mar 28 Avr 2020 - 10:43 | |
| Hello, Frits will stop at nothing! Francis. |
| | | Toop
| Sujet: Re: [GP250] KTM 250 Mar 28 Avr 2020 - 10:44 | |
Oupsssss Here is a surprise, I have to do some simulations and think if I want to integrate this notion, I did not expect that, surprising .... Thanks.
| | | EDOUARD Jean
| Sujet: Re: [GP250] KTM 250 Mar 28 Avr 2020 - 10:45 | |
| Joli sujet qui redémarre bien après une longue réanimation depuis le 1 er Oct 2010 et avec peu de séquelles . |
| | | MANETON
| Sujet: Re: [GP250] KTM 250 Mar 28 Avr 2020 - 10:48 | |
| Merci Frits pour ce partage d'expérience, ce n'est donc probablement qu'une impression ou un "retard" provenant des matériels de mesure en comparaison des thermistances. Pour ma part, quand c'est possible, pour les thermocouples, je conserve aussi les soudures à l'air libre ou simplement les fils "twisted". Sinon, pour certaines applications, nous obtenons de bons résultats avec un "enrobage" laiton. [Vous devez être inscrit et connecté pour voir cette image] |
| | | Marc Admin
| Sujet: Re: [GP250] KTM 250 Mar 28 Avr 2020 - 12:38 | |
| Pas grand chose pour le moment... [Vous devez être inscrit et connecté pour voir cette image]_________________ Un p'tit clik vaut mieux qu'une grande claque; c'est Harry qui l'a dit! [Vous devez être inscrit et connecté pour voir cette image][Vous devez être inscrit et connecté pour voir ce lien] |
| | | Frits Overmars
| | | | pipoff2
| Sujet: Re: [GP250] KTM 250 Mer 29 Avr 2020 - 18:50 | |
| Salut Marc,
merci pour les photos supplémentaires.
pipoff |
| Sujet: Re: [GP250] KTM 250 | |
| | | | [GP250] KTM 250 | |
