| Sujet: Re: [Technique] Carburants Mer 16 Fév - 13:57 | |
| Nascars run on petrol now, Seb. But Indy-cars run on methanol (not ethanol). The stoichiometic value (= how many kg air is needed to burn 1 kg fuel) of methanol is 6,5, compared to 14,7 for petrol. So when you change from petrol to methanol, you'll need jets that are 226% instead of 100%... - Citation :
- Il faut aussi rallonger les pots car la température est beaucoup plus basse que d'ordinaire ......
You might want to reconcider this one, Seb 8). |
| Sujet: Re: [Technique] Carburants Mer 16 Fév - 14:32 | |
| - Citation :
You might want to reconcider this one, Seb 8). [/quote] Hooooppps ( i made a short cut about Nascar/indy/methanol/ethanol , wasn't accurate ...... ) Thanks :) |
